0.99.6 ratings in file view are not saved
user302020
Post by user302020 »
XnView: XnView MP Windows Version 0.99.6 64bits (Dec 10 2021)
OS: Windows 10 - 64-bit
Settings: XMP sidecar
Effect: rating ctrl+"number" is not saved in file view mode
XnView does not save ratings ctrl+"number" on files during file view or fullscreen view
1. Browse a folder (JPEG format).
2. Select any image file.
3. Open file or fullscreen (view) using F11 key.
4. Press ctrl+"number"
Actual behaviour (bug): the rating will be shown in file view but not in browser view, when closing file rating is lost (only rating in browser view is saved)
Expected behaviour: ratings are saved in file view or fullscreen view
Re: 0.99.6 ratings in file view are not saved
even if you restart or change folder?
user302020
Hi Pierre,
actually the rating is written in the XMP file.
But in browser view only visible after restart or when I go to "update catalog from files"
Or when I reopen the folder.
Best regards
This problem is supposed to be fixed in XnView MP 0.99.7. Please check and confirm the bug fix here.
