Convert Tiff to PNG but Retain its transparency
kopox
Post by kopox »
hi guys, how to batch convert tiff to png but retain its transparency? because after converted to png, the background transparency disappear.
i can use Image->transparent color, but it will make all same color transparent which i don't want it.
i attach the image sample that i use which has transparent background on it.
any idea?
Rick
Re: Convert Tiff to PNG but Retain its transparency
Post by Rick »
I can confirm that. In Xnview it did not even show the original as transparent. I loaded it into an editing program and it was visible there.I used Photozoom to convert it and again the transparency was gone
Rick
There is no alpha channel in this file
