Crashes when viewing certain images
kishinnokamen
Post by kishinnokamen »
Whenever I try to view certain images, the application crashes. This is the message I'm given. I use Manjaro KDE Qt 5.15.2 with the 5.15 kernel.
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 255'
### ThumbLoaderThread :: setFirstItemToLoad
 ** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
######ThumbLoaderThread :: forever 2 : 3e3b560
CHECK <0>
######ThumbLoaderThread :: forever : 3e3b560
 ** start condition wait
@@ BitmapResizeThread:: finish (1000, 707) => (1876, 1327)  1.876000
/opt/xnviewmp/XnView: symbol lookup error: /opt/xnviewmp/XnView: undefined symbol: _ZdlPvm, version Qt_5
kishinnokamen
Re: Crashes when viewing certain images
Update. I did some testing in an alternate version. It looks like this only happens if the filtering is set to Spline 16 and above.
could you post an image file?
kishinnokamen
I actually just found that it happens when I put the high-resolution zoom quality anywhere above bilinear.
Strange i can't reproduce...
kishinnokamen
I should note this is with the system libs version, since the other version can't seem to interact with apps in KDE.
