0.99.6 64bits Cannot create Contact Sheet
Rick
Post by Rick »
Version 0.99.6 64bits
When I try to create a contact sheet and click "Create" nothing happens. I have tried changing some of the parameters' to test but nothing worked. The files are there but the create button does nothing. I even searched the Hard drive to see if was elsewhere.
Confirmations anyone? :bug: :bug: :mrgreen:
Rick
Re: 0.99.6 64bits Cannot create Contact Sheet
Not a function I normally use, but it seems to work correctly for me...
First attempt when I clicked 'Create' I had a message to select an output folder.
Does the Preview tab display a preview?
Edit: Produces an output, but I'm not sure whether the output is as expected.
do you have choose an output folder?
bege
Post by bege »
It works as expected here on Windows 10 Professional 64 bit.
Rick
Re: 0.99.6 64bits Cannot create Contact Sheet [SOLVED}
Post by Rick »
I never picked a folder as the folder I wanted to use was prefilled
I chose a folder which was the one already prefilled and it worked correctly
I have a folder that XnView always starts in and that was the one prefilled. Something in there is not right but this will be tough to reproduce
Thanks for the answers!!
Rick
