video's thumbnails not showed
fc622000
Post by fc622000 »
Hello everyone,
in my XnView installation I'm not displayed any thumbnail for videos (OS Windows 10).
Even changing the option "Show 4 thumbnails in video's thumbnail (Instead of 1)" I don't display anything, neither 1 nor 4 thumbnails. Only the file type icon is displayed.
Can someone help me to solve the problem?
Thanks
Re: video's thumbnails not showed
which video format?
fc622000
Post by fc622000 »
It seems for all video formats.
For example, I have some different formats like *.avi *.mpg *.mp4 *.mov but for none of them I can see thumbnails. I have XnView installed on three different PC on all of them I have the same behaviour.
Fabrizio
it's XnView MP not XnView Classic?
fc622000
Post by fc622000 »
Yes, I'm currently use XnView MP. I tried also XnView Classic and it seems that only in some video format the thumbnail are showed: *.avi, *.mpg but not al the other.
I can't reproduce, if you uncheck 'show 4 thumbnails' all is ok?
fc622000
Post by fc622000 »
Unfortunately not. I see the same behaviour regardless of the 'show 4 thumbnails' option setting.
I don't know if it's possible to share some pictures.
you have not changed useInternalVideoPlayer setting (in xnview.ini)?
fc622000
Post by fc622000 »
No, I have not made any changes to the useInternalVideoPlayer setting in xnview.ini.
I checked and the setting is: useInternalVideoPlayer=true
in settings>File list>Custom filter, 'video' is checked for 'Show as thumbnail'?
fc622000
Post by fc622000 »
Perfect!!! Unfortunately, I was not aware of this setting and, for some reason, the "Show as Thumbnail" option for video was unchecked.
Really many thanks!
I would like to take this opportunity to congratulate you on your software, which I think is excellent!
Fabrizio
fc622000 wrote: Mon Jan 10, 2022 11:03 am I would like to take this opportunity to congratulate you on your software, which I think is excellent!
Thanks!!
Giacomo Marchèt
Post by Giacomo Marchèt »
CIAO FABRIZIO
ho avuto anch'io lo stesso identico problema ma grazie a te (per aver posto la domanda) e a Pierre per la risposta, ho risolto nel poter vedere finalmente ora le miniature di circa 1500 video :mrgreen:
fc622000 wrote: Mon Jan 10, 2022 11:03 am Perfect!!! Unfortunately, I was not aware of this setting and, for some reason, the "Show as Thumbnail" option for video was unchecked.
Really many thanks!
Fabrizio
concordo al 100%
Giacomo
Franok39
Post by Franok39 »
xnview wrote: Mon Jan 10, 2022 10:10 am in settings>File list>Custom filter, 'video' is checked for 'Show as thumbnail'?
Perfect, Thank you Pierre! I was searching a lot!
Congratulations to the software. Working since today and I start loving it!
try to set
QT_XCB_GL_INTEGRATION=xcb_egl
