Greetings all,
I'm working on incorporating xnViewMP into my workflow and have bumped into a problem, at least for me.
In the viewer the star rating can be set by ctrl-1, ctrl-2, ctrl; 3, ctrl 4 and ctrl 5.
I've got some serious dexterity issues with my left hand and find this combination virtually impossible to do one handed.
Is there a way just to define the numbers 1, 2, 3, 4 and 5 to assign star ratings?
I'm running xnViewMP on Windows box if that makes any difference.
Thank you
chris
Reassigning ratings keyboard press
doobs
Re: Reassigning ratings keyboard press
That's awesome.
Thank you
Thank you
