I was bored browsing the internet updating some of my software I havent in a while and decided to update XNView from 1.74 (or 1.70.4? ...Oct 2004 version) to 1.8.
So far I havent seen any major enhancments I will likely take advantage of. One difference I noticed immediatly, is that the mouse scroll button zooms the image whereas my old version it would browse next/previous images. Ive searched every pane in the options and cant find anything to change this behavior, and if I cant somehow change that functionality, Id rather just switch back...problem is I dont have my old installer :/
Can anyone link me to an older version, or tell me how to change the keytbinds in the current version if possible?
Where to download older versions?
ckit
SWEET!ckit wrote:I'm using XnView 1.82 beta 1 and the old style has been added!
XnView -> Options -> View -> Keyboard/Mouse -> Mouse wheel -> Prev\Next file
Its there in the current release too! Not sure how I missed it, but now that its back to the way I like it I can start checking out all the new features
Thanks for the quick reply
Various old version of XnView can be found on the XnView Download Server in the subfolder "old_versions". XnView 1.05 is fun to see.
krobra
old tool bar skins
is there anyway to use the older toolbar skins with the newer versions of xnview ???
