Category menu Issues
Gwenael Q.
Post by Gwenael Q. »
Thank you for for the new feature allowing to tag every category with Category menu.
Nevertheless, some small issues were found when tagging a parent category this way :
- Parent category display won't update under image in browser when changing focus.
- Exif data like focal length will disappear, until display is properly updated.
Thank you for listening
Re: Category menu Issues
Gwenael Q. wrote: Sun Jan 16, 2022 11:29 pm - Parent category display won't update under image in browser when changing focus.
What do you means?
you have that only when selecting parent category?
Gwenael Q.
What do you means?
I mean that categories label should update, at least when changing the image(s) selected.
Yes :
Gwenael Q. wrote: Mon Jan 17, 2022 4:38 pm I mean that categories label should update, at least when changing the image(s) selected.
when using {Categories}?
Yes :
I can't reproduce :(
