Face Tag Requests
cicciobello
Face Tag Requests
Post by cicciobello »
Problems seems to be solved.
Assuming you have selected a photo and Tools-Tag Face...
Here some things and suggestions about cosmetic and usability:
- [Keyboard navigation] F2 (Assign a name to face, -working-)
- [Keyboard navigation] Return (Write XMP, -working-)
- [Keyboard navigation] Goto next/previous file: Is it possible to set this with ^+Left/Right arrow?
- [Keyboard navigation] Search face: is it possible to set this with (for example) "S" key or ^/Alt+S?
- [Visual] Left column (with faces) is not resizeable; can contain two face colums, but I have one column only and free space.
- [Interface layout] Button [Search face] is on the opposite side of the faces. For each photo you have to go from right to left, again and again (if not exist a hotkey). Maybe next to [Write]?
- [Interface layout] Previous/Next photo arrow buttons: please make more visible, or grey if there is only one photo and of a different colour if there are two+ photos.
- [Bug] In [Categories Filter|People] select one foto, then ^O: nothing happens. Right mouse button menu: Open containing folder -> Goto folder (correct).
Re: Face Tag Requests
cicciobello wrote: Fri Jan 14, 2022 9:27 pm - [Keyboard navigation] Goto next/previous file: Is it possible to set this with ^+Left/Right arrow?
Left/Right is used to navigate into faces
will be added
right, but 'search face' is automatically applied on image??
ok
I can't reproduce
cicciobello
xnview wrote: Mon Jan 17, 2022 11:55 am
I suggest Ctrl+Left/Right Arrow to change file. With this, you can tag faces between multiple files without using mouse.
Oh yes, now "search face" automatically start (this is OK).
ok
With default/light theme these buttons are grey-on-grey. Bigger and coloured are better, and hotkey to change file is super.
I can't reproduce
Uff... :-(
I have this also in 0.99.7 (fresh install). But don't worry, this is a little bug.
