In the browser I can open a file with its associated program by >Right click >Open with... >Associated program (F3).
This works perfectly.
Opening the file with its associated file by pressing F3 works as well.
NOW, I would like to chang the Hotkey from F3 to Ctrl+Shift+Tab. But I cannot find the command "Oewn with... associated file" in the dialog box >Tools >Setting... >Interface >Shortcuts. So, where can I change the shortcut definition from F3 to Ctrl+Shift+Tab?
Modify Keyboard Shortcut Alt+1 (Open with PROGRAM)
StreifLicht
Re: Modify Keyboard Shortcut Alt+1 (Open with PROGRAM)
currently no way
batteryeraser
How about four years later, anything different?
What's preventing a simple shortcut change, anyway? There doesn't seem to be any rhyme or reason to which ones aren't allowed to be modified.
