0.99.7 64bits – *.SVG files
SoCu
Post by SoCu »
Hi, I have a problem with displaying *.SVG files, I can't display them, the SVG files contained in the folder are not displayed either
And also the XnShell does not appear in the context menu of the mouse.
The files I am trying to view are the ones in this web page
https://proyectoviajero.com/banderas-de ... -imagenes/
Is there a plugin that can be put in the plugin folder to be able to view any SVG, whether it is vector or non-vector?
best regards.
Re: 0.99.7 64bits – *.SVG files
Check in Settings>filelist>Custom filter - Exclude
SoCu
Post by SoCu »
( ͡~ ͜ʖ ͡°)
