XnView MP version 0.99.7 64bit portable
OS: Windows 11 Home, version 21H2, OS build 22000.469
Configuring the settings for XnViewMP to exit after hitting the "escape" key does not work. It will clear XnViewMP's display of the thumbnails but not exit. This is what it looks like:
Pressing escape does not exit the program
fastedward
Re: Pressing escape does not exit the program
do you have Settings>Interface>Tabs - closing last tab..?
fastedward
Yes, Settings>Interface>Closing Last Tab Exits XnView is checked.
Also have this one: Interface>Keyboard>Pressing ESC once quits XnViewMP = Always
it works here, you press ESC in browser or in edit mode?
