0.99.7: Resizing 180k photos Estimated end time shows time hours and minutes only
pd2
Post by pd2 »
Minor bug. Hope you don't mind me mentioning it.
Subject: 0.99.7: Resizing +-180k photos estimated end time shows hours and minutes only
XnView: MP 0.99.7 - 32 bit
OS: Windows 10 64bit
Description: The estimated end time shows, it looks like, the time to finish the current image but should, in my case say 1 day, x hours, x minutes.
Effect: Program runs without problem. Well I think so. I'll let you know tomorrow!
1. Find a large quantity of images to resize
2. <Step 2>
3. ...
Actual behaviour (doesn't show days to run bug)
Expected behaviour: Show days, hours, minutes etc
pd2
Re: Subject: 0.99.7: Resizing 180k photos Estimated end time shows time hours and minutes only
Post by pd2 »
I can send a screen shot if it is useful
masterjp
Post by masterjp »
The estimated end time is not very precisely with huge amount of files in batch conversion. :(
I can confirm it. I converted thausends of jpeg files to webp and sometimes the estimated time stay at 0 seconds,
although XnViewMP has e.g. 300 of 1.000 files done.
I would save the starttime and whole size of all input files. Then I would compare the past time with the filesize of the all converted input files.
So you can calculate the estimated end time.
