Draw Panel (Shift+D)
josedumoretzsohn
Post by josedumoretzsohn »
I suggest the Draw Panel (Shift+D/Umschalt+D), also in XNview Classic, should offer the possibility of changing the background color (the color of the panel itself, which is always black), because when we want to draw on an image that has itself a black background — which I have often — we cannot tell where the image borders end, thus difficulting, and many times unabling it altogether, the process of drawing on the image itself. Thank you.
Re: Draw Panel (Shift+D)
1.0 version now use the color from settings>Background
