Handling transparency when converting PDF to PNG
chrishaas
i'm trying to convert PDFs to PNGs and i'm not sure on how to maintain their transparency. i see two options in the help file, transparent and transpcolor. i can't use the latter because there isn't anything there in the first place and i don't know what the former means. any help would be great!
Re: Handling transparency when converting PDF to PNG
Transparency of PDF file? Sorry you can't!chrishaas wrote:i'm trying to convert PDFs to PNGs and i'm not sure on how to maintain their transparency. i see two options in the help file, transparent and transpcolor. i can't use the latter because there isn't anything there in the first place and i don't know what the former means. any help would be great!
