pdf option under "write"
Locked
MAAD
Post by MAAD »
the quality indicator is always on even if you choose "none" which is also has no description..
1-the first bar has to be "compression type"
2-the second "quality quage" is only for lossy format like JPEG (,JB2,JP2) "if added"
thanks..
MAAD
Re: pdf option under "write"
MAAD wrote:the quality indicator is always on even if you choose "none" which is also has no description..
Ok
Xyzzy
Post by Xyzzy »
Present in b1 fixed in b2 for me.
X.
Locked
