Disable Crop when dragging mouse on a large view?
FKCapitalism
Post by FKCapitalism »
Is there way to disable the crop function when you drag the mouse to make a selection in a large view and instead have zoom?
Re: Disable Crop when dragging mouse on a large view?
For zooming you can use Ctrl + Mouse wheel. And in XnView setings (Menu "Tools » Settings" | Category "Interface » Mouse") you have various options for adjusting XnView's behaviour. E.g. you can set left mouse button to "Zoomed selection" and then drag the mouse to select an area and then release mouse button and let XnView zoom into it.
