Demo image:
What it looks like:
p.s. I'm using 4k monitor with 150% UI sacling
Fake white line when viewing image
BK201
Re: Fake white line when viewing image
I've downloaded your image and tried out in XnView MP 0.99.7 on Windows 10. The image is displayed without white line, see below.
I've tried to reproduce the problem by changing various XnView settings (Tools >> Setting | Category View > View) but without success, i.e. no white line. I suspect that Windows does some anti-aliasing to improve screen quality.
- Could you perhaps change your scaling to 100% and then see whether the problem persists?
- Which version of XnView MP do you use?
- Could you please take a screenshot of your settings in Tools >> Settings | Category "View" | Tab "View" and post it here?
BK201
No, just confirmed it's (another) bug related to UI scalinghelmut wrote: Sun Feb 13, 2022 9:24 am - Could you perhaps change your scaling to 100% and then see whether the problem persists?
0.99.7
It's not related to that
Does this mean that the problem no longer occurs if you set your UI scaling to 100%?BK201 wrote: Sun Feb 13, 2022 4:13 pmNo, just confirmed it's (another) bug related to UI scaling ...
BK201
yeshelmut wrote: Sun Feb 13, 2022 4:49 pmDoes this mean that the problem no longer occurs if you set your UI scaling to 100%?BK201 wrote: Sun Feb 13, 2022 4:13 pmNo, just confirmed it's (another) bug related to UI scaling ...
BK201
BK201
This bug is still not fixed in 1.0
rogi
I have the same problem when cropping .png files. My system scale is 125%, I use second monitor with 1440p resolution.
XnViewMP v.1.5.0.
XnViewMP v.1.5.0.
could you describe your problem?rogi wrote: Sat Jul 22, 2023 10:14 am I have the same problem when cropping .png files. My system scale is 125%, I use second monitor with 1440p resolution.
XnViewMP v.1.5.0.
xmozg
This is the same as my reported bug "artifacts when viewing with hq algorithms":
viewtopic.php?f=62&t=45677
The same gray bar at the bottom of the image is due to the use of scaling.
I think if the common cause of the gray bar on the bottom is fixed, a lot of the bugs associated with the bar will also disappear.
