16-bit per pixel TIM image is seen as 8-bit per pixel
aybe
Post by aybe »
XnView MP 0.99.7 64-bit
Windows 10.0.19044.1526
Incorrect bit-depth reported by XnView MP for TIM files.
1. unzip the attachment as TIM file couldn't be attached as such
2. browse to where the file is with XnView MP
3. see that bit-depth is 8 while it should be 16
Expected behaviour:
TIM files with a bit-depth of 16 should not be reported as with a bit-depth of 8.
Thank you :P
Re: 16-bit per pixel TIM image is seen as 8-bit per pixel
RGB is packed as 16bits, but not 16bits per component
aybe
Post by aybe »
Don't you think there's some discrepancy in the following?
I mean, if I follow you, then all should be 8 but currently 4bpp reports 4, 8bpp reports, 24bpp reports 24 but 16bpp reports 8 which makes no sense.
Or did I simply miss something in what you've said? :D
aybe wrote: Tue Feb 15, 2022 8:21 am Don't you think there's some discrepancy in the following?
Yes, the first one should be reported as 192x144x24 and not 8
aybe
Post by aybe »
Actually, a 16-bit TIM may either:
#1 remain 16-bit if any of its pixel does not have the STP bit set.
#2 become 32-bit if any of its pixel has the STP bit set, this is because it actually is, semi-transparency, if it wasn't then it could simply be a 15-bit + 1 bit of transparency like TGA format supports.
As for the semi-transparency algorithm, it's a bit contradictory in the PDFs you can find at psxdev.net, the file format specifies one way in table 3-1 at page 182, while the runtime library overview in table 8-11 at page 107 specifies the same but for one case.
Now that really is the cake topping, I understand that there may be higher priority bugs to solve than this one within XnView MP. :D
