0.99.7: text input focus lost when using clipboard manager
AldoDz
Post by AldoDz »
Subject:0.99.7: text input focus lost when using clipboard manager
XnView MP MacOSX
Version 0.99.7 64bits (Jan 13 2022)
Related Software: Paste 3.1.5 (https://pasteapp.io/)
bought license, not subscription
when editing a file name in thumbnail pane, then using a clipboard manager to select the paste string, on return focus and position is lost in text input
Effect: focus is lost, text input must be selected again and cursor positioned, then redo the paste
in other programs focus stays and paste helper is able to enter the paste string into the correct position
1. in thumbnail pane select a file name input
2. position cursor to where paste string should go
3. enter clipboard manager and select paste string
Actual behaviour (bug): focus returns XnView window, but text input is not focused, paste string is not entered :bug:
Expected behaviour: focus returns to XnView, focus stays in text input and paste helper is able to enter the paste string into the correct position
AldoDz
Re: 0.99.7: text input focus lost when using clipboard manager
Post by AldoDz »
To be more specific, any context switch will do the sama, whether to clipboard manager, finder or whatever
probably in any input in any pane as well
