The developer of FileOptimizer (https://nikkhokkho.sourceforge.io/stati ... eOptimizer)
use a free guetzli jpeg encoder executable file with CPU/CUDA/OPEN CL hardware acceleration.
The benchmarks are amazing and the best of it - the program can detect your GPU and choose the fastest way to save a guetzli jpeg file.
You can replace the existing guetzli encoder exe of xnviewmp with this one.
Every user with or without compatible GPU can use it.
I think you need the paramter --c for auto detection of the hardware.
Website:
https://github.com/ianhuang-777/guetzli-cuda-opencl
Fast Guetzli JPEG Encoder with CUDA/Open CL at github
masterjp
jgutierrez
Re: Fast Guetzli JPEG Encoder with CUDA/Open CL at github
Agree with the sujection, and thank you so much for using FileOptimizer.masterjp wrote: Sun Feb 20, 2022 7:21 pm The developer of FileOptimizer (https://nikkhokkho.sourceforge.io/stati ... eOptimizer)
Website:
jgutierrez
BTW, version used at FileOptimizer is this one:
https://github.com/doterax/guetzli-cuda ... its/master
masterjp
Thanks for your post.
I took the guetzli encoder link from the main FileOptimizer website, but I should be the old one.
Tschens
I think the CUDA version will NOT work with XN_View by simply exchanging the exe file in the plugin folder, since the CUDA version needs the parameter --CUDA in order to work 20x faster. I dont see any option how to set this parameter in XN_View. It simply calls the exe file from the plugin folder without any parameter, and this means: standard (slow) mode.
Olympus OMD E-M1, BS Kinetics underwater housing, 2xSubtronic pro 160 flashes. Zuiko mFT lenses: 60 macro, 7-14, 8 mm fisheye, 12-100, PanaLeica 100-400.
My Homepage | My book at Amazon
doterax
We started working on this problem hereTschens wrote: Thu Nov 23, 2023 10:25 am I think the CUDA version will NOT work with XN_View by simply exchanging the exe file in the plugin folder, since the CUDA version needs the parameter --CUDA in order to work 20x faster. I dont see any option how to set this parameter in XN_View. It simply calls the exe file from the plugin folder without any parameter, and this means: standard (slow) mode.
