ICC options not working on MacOs
UrbanCoyote
Post by UrbanCoyote »
Hi there,
No ICC options seem to work on MacOs.
I've a wide gamut monitor, so all my jpegs are heavily saturated.
Putting the monitor profile into the ICC options doesn't seem to work, nor any of the other options.
Re: ICC options not working on MacOs
which settings do you have in 'ICC', and which profile do you use?
UrbanCoyote
I have it set like this, however I can't see a difference with it on or off.
I use PaletteMaster from Benq to generate the ICC profile for the wide gamut monitor.
It seems PS, Affinity Photo, Lightroom and Capture One, and other apps like Preview and Finder use it.
could you send me the icc profil, and a jpeg file?
UrbanCoyote
Sure, here's one - the oranges and reds seem to be strong..
it's strange, because BenQ profile is sRGB and image too (by default), so no change...
