Hello there!
Since version 0.99.7 I encounter the problem that some internal window sizes (preview, properties...) are reset to a default value. I always have to resize it. If application is closed and reopened this behavior returns.
Screen resolution is 4k. For miniature are 4 lines and 12 colums selected. After reopening XnView MP there are 5 lines. Last line ist not completly to see. Labeling ist partially covered.
The right setting...
The setting after closing and reopening...
Is there a solution to save the sizes to the desired value and keep them fixed? I did'nt found any appropriate setting yet.
Thank you and regardes!
arne
window sizes always reset when application starts
aj74
Re: window sizes always reset when application starts
XnView is maximized when quitting?
aj74
Hello Pierre!
Thank you for answering.
First: Yes, it is maximized.
Second: Yesterday night I could solve this by deleting xnview.ini and creating a new one. Maybe this behaviour results in installing a new version over an existing one?
This way many settings got lost and a wide reconfiguration was needed. But all windows inside the program keep their size now.
Any idea?
Regards,
Arne
Any idea?
Regards,
Arne
