How to use XnSketch's and XnRetro's effects in XnViewMP?
WhiteBear
Post by WhiteBear »
Hello!
How to use XnSketch's and XnRetro's effects in XnViewMP directly?
Thank you in advance
Re: How to use XnSketch's and XnRetro's effects in XnViewMP?
currently not implemented in XnView
WhiteBear
Post by WhiteBear »
xnview wrote: Mon Mar 07, 2022 1:15 pm currently not implemented in XnView
Is this in plan? It would be very conveniently to have all effects in one application.
As for now I put XnSketch.exe (and a couple of additional files) in the XnViewMP's folder and it works. XnRetro — not (it uses Qt4). But anyway it's just a workaround. So is this in schedule?
Thank you in advance.
