Viewing files in the viewer
Locked
Danny
Post by Danny »
I think there's some incosistency with the viewer. Let's say you're using dblclick to switch modes.
If you're viewing a picture in fullscreen view, dblclicking it again will bring you back to the browser and close the picture. Great.
But the same doesn't apply to the viewer mode. Dblclicking an opened pictured will only switch back to the browser and leave the viewer tab opened. If you then click on the same image in the browser, it will open a 2nd viewer with the same picture. Needless.
Thoughts?
Xyzzy
Post by Xyzzy »
Use View>Only one view opened to have no more than 1 View window opened.
I guess there is no option to autoclose image when switching with double-click or option to reuse tab with already opened file (?).
X.
Danny
Post by Danny »
Xyzzy wrote:Use View>Only one view opened to have no more than 1 View window opened.
That kinda works actually. :? Forgot about that option.
Danny
Post by Danny »
Well, after working with that option enabled, i found reason why this is not an ideal solution: the tab feature is practically gone for me, since there's always just one viewer tab.
So is there any reason not to do it as i have suggested in my 1st post?
Xyzzy
Post by Xyzzy »
Tabs>Hide tabs when only one window is opened.
X.
Danny
Post by Danny »
Xyzzy wrote:Tabs>Hide tabs when only one window is opened.
X.
What does that have to do with my problem? My problem is, that there's no way to have just one tab per file.
So my question again: Who needs to have the same file opened on more than 1 tab at a time?
Locked
