When using the draw tool it is possible to draw a shape on the screen that extends outside the image canvas:
When the above image is saved, only two horizontal lines extending across the width of the canvas are added to the image.
Draw tool - Possible to draw shape outside image canvas
Re: Draw tool - Possible to draw shape outside image canvas
you would like that drawing will be clipping by image rectangle?
My thinking was that when drawing a shape, it shouldn't be possible to move the mouse cursor outside the edges of the image canvas being annotated, if that can be implemented?xnview wrote: Mon Apr 11, 2022 1:08 pm you would like that drawing will be clipping by image rectangle?
So the rectangle tool, for example, would always draw a rectangle.
