Whenever I start viewing images, the program usually stops responding after a short while.
Details:
• When it stops responding, none of the keys work and Windows reports that the program has stopped responding.
• It will start responding again if I wait long enough.
• The problem seems to affect any type of file, even if the folder only contains JPEGs.
• The problem doesn't seem connected to any particular action. It will randomly stop responding even if I'm doing the same thing over and over, or doing nothing at all.
• I've never had this problem with any previous version of XnView (the last version I used was 0.98.1).
• The program also seems sluggish at times. For example, I can open an image, hit the "previous image" key, and the previous image will load instantly. But then, a few seconds later, I will go back and do the same thing, and it may take a second to appear.
My specs:
Windows 7 x64
Intel Quad Core i7 860 2.80GHz
Sapphire ATI Radeon 4670 HD 750Mhz 512MB PCI-Express DVI
0.99.7 Randomly stops responding
Re: 0.99.7 Randomly stops responding
always? Do you have send a crash log?
