0.99.7 ORF files from OM-1 are not opened
pawellabaj
Post by pawellabaj »
XnView: MP 0.99.7 64bit
OS: Mac
ORF (Olympus RAW) files from the new Olympus body OM-1 are not opened in the program.
1. Open folder with ORF files
Actual behaviour (bug): Thumbnails are not being displayed. It's impossible to open a picture on full screen :bug:
Expected behaviour: Thumbnails are visible and it's possible to open a picture on full screen.
Re: 0.99.7 ORF files from OM-1 are not opened
could you send a sample file?
pawellabaj
A file is too big to attach to the thread. Please, download it from here: https://drive.google.com/file/d/1NvOkTQ ... sp=sharing
this format will be supported in 1.0, you can try the beta version
pawellabaj
I've installed the beta version. It works.
Thanks @xnview
