1.0 beta: Next and Previous file operations now working in folder
cirrus.hashed
Post by cirrus.hashed »
XnView MP MacOSX
Version 1.0 64bits (Mar 28 2022)
* Prev file and Next file operations are not working when using arrow keys, <space> or <enter> keys.
* Even when setting 'custom' keyboard shortcuts, these operations are not being triggered.
Effect: Cannot navigate through images in any folders.
1. Open XnView MP in browser mode.
2. Navigate to a folder with multiple files
3. Click/press Enter on any file in the folder to enter Viewer mode.
3. Attempt to view the next or previous files by pressing either:
a) Up/Down/Left/Right arrow keys
b) Spacebar key
c) Enter key
d) fn+Up and fn+Down (attempt to emulate PgUp and PgDn as per default keyboard shortcut mapping)
Actual behaviour: Nothing happens
Expected behaviour: Next / Previous image in the folder is displayed
Other notes:
* This is happening on both local folders and network shares.
* When setting custom keyboard shortcuts on Mac, the original previous correctly shows the 'Option' and 'Cmd' icons. But `onKeyUp`, they revert back to Shift, Ctrl, Alt.
Keyboard shortcut custom oddity
Re: 1.0 beta: Next and Previous file operations now working in folder
is it a new issue of 1.0?
cirrus.hashed
Yes, reverting back to Version 0.99.7 64bits (Jan 13 2022), everything works as expected.
cirrus.hashed wrote: Fri Apr 01, 2022 12:23 pm Yes, reverting back to Version 0.99.7 64bits (Jan 13 2022), everything works as expected.
Please re-download the package, there was an build error
cirrus.hashed
Can confirm the latest build fixes the issue.
