b2 bug: thumbnails and thumbnails + labels must be excha
klumy
Post by klumy »
beta 2 bug: thumbnails and thumbnails + labels must be exchanged
thumbnails shows thumbnails + labels
and thumbnails + labels shows just thumbnails
XnView 1.82 -
XNView 1.91.5
Windows XP SP3
Dreamer
Post by Dreamer »
Can't confirm.
Dreamer
Normal here
:) Hello !
- Same, I can't confirm, that works normally here.
:mrgreen: KR
marsh
Re: b2 bug: thumbnails and thumbnails + labels must be excha
Post by marsh »
klumy wrote:beta 2 bug: thumbnails and thumbnails + labels must be exchanged
If you're using an old "ini" file, then previous labels are not remembered (it will look as you have described).
Yes, so label shown must be filename for him!
klumy
Post by klumy »
after deleting the ini file it works now ;)
XNView 1.91.5
Windows XP SP3
klumy wrote:after deleting the ini file it works now ;)
Good to read. But if possible we should check and make sure that when updating and using an old .ini XnView still behaves properly.
klumy
Post by klumy »
yes, this would be important :D
XNView 1.91.5
Windows XP SP3
Yes, but currently a problem because some big changes...
