XnView: MP 0.99.7 - 64 bit
OS: Windows 10 - 64bit
XnView can't open AVIF file if the file location has kanji character. I got an error message: "File can't be loaded!"
1. Create a folder that has kanji character, e.g. test般
2. Put the AVIF file in the folder
3. Try to open the AVIF file with XnView MP
4. You'll get an error message: "File can't be loaded!"
5. Rename the folder 'test般' to 'test'
6. Try to open the AVIF file again
7. File will be loaded successfully
Actual behaviour (bug): Got an error message "File can't be loaded!" when trying to open AVIF file located in a folder that has kanji character.
Expected behaviour: File should be loaded.
I also attached the AVIF file for testing.
0.99.7: Can't open AVIF file if file location has kanji character
- Attachments
- 00003.7z
- (43.99 KiB) Downloaded 203 times
Re: 0.99.7: Can't open AVIF file if file location has kanji character
Confirm that the bug is fixed in XnView MP 1.00 beta 3.xnview wrote: Mon Apr 11, 2022 12:56 pmThanks to your detailed description I can reproduce the problem.
Thank you
