Extremely small font in 4K resolution screen
sibojan
With 4k resolution (3840 x 2160 pixel), The font in some windows is extremely small causing vision obstacle. Please see the pictures for details. Thanks.
Re: Font issue in 4K rusolution screen
which font scaling do you use?
sibojan
if you use 200% no more issue?
sibojan
Interesting. That solves the problem of Xnview, but make the global font in Win10 become smaller.
Since the 250% scale is the default option in Windows, I suggest optimizing Xnview to fit Win10 instead of doing it conversely.
Currently the QT librairies has problem with 150/250%
sibojan
I am still using 250% scaling. The issue went away today itself. Weird.
