Sidecars to separate folder.
AdorableWolf
Post by AdorableWolf »
To be fair. I did abandon XnView for some time and gave it another try today. I understand now how sidecars works on gifs and png. I move/edit/delete file, the sidecard follows -> neat.
All I wonder is this: Since I see that it is just fine to put sidecart to a different folder -> it still keeps the categories intact. Is it possible to put those in a separate folder AND still keep the functionality of rename/delete when main file is gone? -> If I did it now like this, it would lead to broken links if I ever remove main pictures leaving useless xmp sidecarts to those files.
Re: Sidecars to separate folder.
no sidecar must be in same path as original file
AdorableWolf
Oki. Considered to add? I mean it is no big deal breaker if I get used to do EVERYTHING through the app since we can hid it.. just.. you know.. organised..
