XnViewMP hangs at Start
TommyD
Post by TommyD »
i use XnViewMP on Ubuntu. Sometimes i can't start the application. There is an xnview-icon in the panel but when i try to maximize the app nothing happens. when i start xnviewmp from terminal it return this:
==> 1,000000  1,000000  30,480000  96,000000  (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1920 1031
w.init
XNVIEW SIZE 1920 1031
########### BrowserWindow :: BrowserWindow
libpng warning: iCCP: known incorrect sRGB profile
MENU install : 0x2fac490
ThumbLoaderThread :: stop()
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (1920 1031)
BrowserWindow :: restoreState => 1920 1031
                              => 1658 760
BrowserWindow :: restoreState ok => 1658 760
XNVIEW SIZE ok 1920 1031
Sometimes after a reboot xnviewmp works. This is the only application with that problems. I have this problems since more then a year with different versions.
Re: XnViewMP hangs at Start
do you have tried to use a clean xnview.ini?
TommyD
Post by TommyD »
At the Moment the program is running because has Bern rebooted in the meanwhile.
But in the last few month i also deleted the ini but that doesnt solve the Problem.
