Shortcut to switch specific image when comparing
sogangee
Up to 4 images can be compared at the same time in side by side or toggle between (Check "Use tabs"). When comparing more than 2 images, often need to toggle between image 1 and image 3, for example. I can choose image 2 and 3 using mouse, but in that case, I have to move my eye to the mouse cursor and then come back to the image every time toggling. If a shortcut is supported to select a specific image to toggle (ex. Alt + 1, 2, 3, or 4), it would be really helpful.
Timur Born
Re: Shortcut to switch specific image when comparing
Very much "yes, please". Keyboard shortcuts to switch between 1-4 images and a shortcut to switch between tabbed mode and side-by-side mode is what I miss most. Shortcuts for various zoom levels would also be useful (and the possibility to set arbitrary zoom levels to better compare different resolution images).
I keep going back to the Faststone Image Viewer just for the comparison tool, but I would prefer staying with XnViewMp for all image viewing needs.
+1 (Sounds like a simple and important enhancement to me.)
yes will be added
Timur Born
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
potac
Hello. I cannot see in the shortcuts list which is the default combination of keys to switch between images
JakubCech
Guys, I found it - press space to switch between tabs.
