Empty Panels after restoring a custom layout
Marcel
Post by Marcel »
I have a dual monitor setup, and made some changes to the custom layout for example moved my category filters etc. to the second screen for better access and visibility. Worked fine, but when i click i.e. restore layout B - only white panels appear.
Restoring inside the main window is no problem.
https://www.screencast.com/t/v40Wkgfq
Thanks,
M
Re: Empty Panels after restoring a custom layout
Even after a restart of XnView?
Marcel
Post by Marcel »
I figured, it will work after restarting the Programm in the new layout. Just when I switch Layouts during operation it won´t work. Quick workaround :) Thanks!
it should work, please send me the layout files?
Marcel
Post by Marcel »
Thanks, i will do when i am back at my workstation in 2 weeks. :)
