XnView: MP 1.00 beta3 - 64 bit
OS: Windows 10
When browsing folder structure in ZIP archives folders and then exiting XnView, XnView will not open the last recently browsed folder.
Effect: Wrong folder is displayed at start-up
1. Download the ZIP archive "Numbers.zip" attached to this topic and save it on a local drive. Do not unpack it.
2. Start XnView MP and browse the archive.
3. Double-click on thumbnail of subfolder "Numbers". --> Subfolders "A", "B", "C" and files "1" and "9" are shown.
4. Exit XnView
5. Start XnView
Actual behaviour (bug): XnView will open up in program directory, i.e. the directory where executable xnview.exe is located.
Expected behaviour: Most recently browsed folder (i.e. the folder where the ZIP archive is located in) is displayed by XnView at start-up.
1.0 b3: ZIP archive: Last browsed directory doesn't work
Re: 1.0 b3: ZIP archive: Last browsed directory doesn't work
Behaviour is a bit better but still not correct:
Program directory of XnView is no longer opened which is good.
Actual behaviour: XnView MP starts up with the last recently used folder of the session that was before the last session.
Expected behaviour: XnView MP is supposed to open folder that contains the ZIP archive which was browsed when exiting.
yes, need to be changed
