Enter key won't start search
kxmp
Post by kxmp »
Using 0.99.7 on win7x64
ctrl+f to open the search window
Enter the string that you want to search.
After you typed it then use enter key to start the search
Something like this appeared after the enter key pressed and search won't start
I think the focus should be on 'search' by default.
And if you click the search, the browse button is not focused when search is finished .
It makes you can't press enter key again to let it show the result of search.
Re: Enter key won't start search
Thank you for the good suggestions, kxmp.
kxmp wrote: Thu Apr 28, 2022 5:21 pm... I think the focus should be on 'search' by default.
Right, "Search" button should be default button, i.e. the button that is triggered when you press "Enter".
kxmp wrote: Thu Apr 28, 2022 5:21 pm.. And if you click the search, the browse button is not focused when search is finished .
Right, once a search is finished "Browse" button is supposed to be focused and/or default button.
