LAN is not accessible via XnView under Windows 10
hertzfrequentz
Post by hertzfrequentz »
I have a problem with access to network drives on my Windows 10. Mapped drives (with letters) are not listed in tree view.
If I try to open an image file (via Windows Explorer context menu) I get messagebox 'file doesn't exist'.
Also if I create a shortcut to network folder - it is not listed in Xnview in folder explorer mode. So program itself probably reads destination pointer and if it is network location - is not listed to access anything.
I tried to find proper option in xnview preferences settings to on/off such network support but i failed.
I can deliver more informations/screenshots if you ask.
Thanks in advance.
Re: LAN is not accessible via XnView under Windows 10
you don't use NoDrives registry entry?
hertzfrequentz
PS. OK Problem solved. It was my mistake - I had an old version xnview from 2020 (0.95) and it seems it was a problem.
