Cannot see and save aivf format (Windows 7)
jazei
I did the change to 64 bit and installed the patch for direct x you recomend but nothing: I can not see and save in avif format
Re: I downloaded MP 64 bits and patch for win 7 but I can not see and save aivf format
perhaps you need to install VisualC++ redistribuable dll
jazei
I downloaded and installed of course it and the same for the patch before, but XnView does not show avif files in the interfase of Xnview exporer of a folder that contains a mix of .jpg .webp and .avif (avif made by another program "paint.net") files of my PC, even the data of the avif file created by XnView shows size: 0 bites!!!!! see screenshot using windows explorer: below say = 0 bites
whe I open this WxView file.avif in paint.net the detail of the error encouter is this:
Exception:
System.FormatException: The file does not contain a FileType box.
at AvifFileType.ExceptionUtil.ThrowFormatException(String message)
at AvifFileType.AvifParser.CheckForRequiredBoxes()
at AvifFileType.AvifParser.Parse()
at AvifFileType.AvifParser..ctor(Stream stream, Boolean leaveOpen, IArrayPoolService arrayPool)
at AvifFileType.AvifReader..ctor(Stream input, Boolean leaveOpen, IArrayPoolService arrayPool)
at AvifFileType.AvifFile.Load(Stream input, IArrayPoolService arrayPool)
at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src_4_3_x\Data\FileType.cs:line 498
at PaintDotNet.Data.FileTypeProxy.OnLoad(Stream input) in D:\src\pdn\src_4_3_x\PaintDotNet\Data\FileTypeProxy.cs:line 58
at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in D:\src\pdn\src_4_3_x\Base\Functional\Func.cs:line 158
Diagnostics:
Application paint.net v4.3.10 (Stable 4.310.8103.32785)
Build Date miércoles 9 de marzo de 2022
Install type Classic
Representación acelerada por hardware (GPU) False
Remote session False
Animaciones False
DPI 96 (1,00x scale)
Idioma es-ES
OS Windows 7 Professional Service Pack 1 x64 (6.1.7601.0)
Runtime .NET 6.0.3 x64
Physical Memory 4.061 MB
CPU Intel(R) Celeron(R) CPU E3400 @ 2.60GHz
Speed ~2599 MHz
Cores / Threads 2 / 2
Features SSE, SSE2, SSE3, SSSE3
Video Card Intel(R) G41 Express Chipset
Dedicated Video RAM 64 MB
Dedicated System RAM 0 MB
Shared System RAM 1.631 MB
Vendor ID 0x8086
Device ID 0x2E32
Subsystem ID 0x31031565
Revision 3
LUID 0x0000BD35
Flags None
Graphics Preemption DmaBufferBoundary
Compute Preemption DmaBufferBoundary
Outputs 1
Feature Level Direct3D_10_0
DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float
Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc
Managed assemblies 75
System.Private.CoreLib .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e
paintdotnet .\paintdotnet.dll, Version=4.310.8103.32785
System.Runtime .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PaintDotNet.Base .\PaintDotNet.Base.dll, Version=4.310.8103.32785
System.Windows.Forms .\System.Windows.Forms.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e
PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=4.310.8103.32785
System.Runtime.InteropServices.RuntimeInformation .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PaintDotNet.SystemLayer.Native.x64 .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.310.8103.32785
System.Threading .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
PaintDotNet.Core .\PaintDotNet.Core.dll, Version=4.310.8103.32785
System.Private.Uri .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
WindowsBase .\WindowsBase.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
PresentationFramework .\PresentationFramework.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Xaml .\System.Xaml.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
System.Collections .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.ComponentModel .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=4.310.8103.32785
System.ObjectModel .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Threading.Thread .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PaintDotNet.Data .\PaintDotNet.Data.dll, Version=4.310.8103.32785
Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
System.Collections.Specialized .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Collections.Immutable .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Private.Xml .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
System.Net.WebClient .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=4.310.8103.32785
System.Memory .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Drawing.Common .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Linq .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PresentationCore .\PresentationCore.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Security.Claims .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
DirectWriteForwarder .\DirectWriteForwarder.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
UIAutomationTypes .\UIAutomationTypes.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=4.310.8103.32785
Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.Loader .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.11.0
AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.19.0
System.IO.Packaging .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.11.0
System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.CodeDom .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
System.Console .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Runtime.CompilerServices.Unsafe .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Diagnostics.StackTrace .\System.Diagnostics.StackTrace.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
System.Reflection.Metadata .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
Native modules 245
paintdotnet.exe .\paintdotnet.exe, version=4.310.8103.32785
ntdll.dll C:\Windows\SYSTEM32\ntdll.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
aswhook.dll C:\Program Files\Avast Software\Avast\aswhook.dll, version=22.3.7108.0
kernel32.dll C:\Windows\system32\kernel32.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432)
KERNELBASE.dll C:\Windows\system32\KERNELBASE.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432)
USER32.dll C:\Windows\system32\USER32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
GDI32.dll C:\Windows\system32\GDI32.dll, version=6.1.7601.24540 (win7sp1_ldr_escrow.191127-1706)
LPK.dll C:\Windows\system32\LPK.dll, version=6.1.7601.24537 (win7sp1_ldr_escrow.191114-1547)
USP10.dll C:\Windows\system32\USP10.dll, version=1.0626.7601.24535 (win7sp1_ldr_escrow.191105-1059)
msvcrt.dll C:\Windows\system32\msvcrt.dll, version=7.0.7601.17744 (win7sp1_gdr.111215-1535)
SHELL32.dll C:\Windows\system32\SHELL32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
SHLWAPI.dll C:\Windows\system32\SHLWAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
ADVAPI32.dll C:\Windows\system32\ADVAPI32.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707)
sechost.dll C:\Windows\SYSTEM32\sechost.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
RPCRT4.dll C:\Windows\system32\RPCRT4.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
api-ms-win-crt-runtime-l1-1-0.dll .\api-ms-win-crt-runtime-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
ucrtbase.DLL .\ucrtbase.DLL, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-localization-l1-2-0.dll .\api-ms-win-core-localization-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-processthreads-l1-1-1.dll .\api-ms-win-core-processthreads-l1-1-1.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-file-l1-2-0.dll .\api-ms-win-core-file-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-timezone-l1-1-0.dll .\api-ms-win-core-timezone-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-file-l2-1-0.dll .\api-ms-win-core-file-l2-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-synch-l1-2-0.dll .\api-ms-win-core-synch-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-stdio-l1-1-0.dll .\api-ms-win-crt-stdio-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-heap-l1-1-0.dll .\api-ms-win-crt-heap-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-string-l1-1-0.dll .\api-ms-win-crt-string-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-convert-l1-1-0.dll .\api-ms-win-crt-convert-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-locale-l1-1-0.dll .\api-ms-win-crt-locale-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-math-l1-1-0.dll .\api-ms-win-crt-math-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-time-l1-1-0.dll .\api-ms-win-crt-time-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
IMM32.DLL C:\Windows\system32\IMM32.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255)
MSCTF.dll C:\Windows\system32\MSCTF.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
hostfxr.dll .\hostfxr.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
api-ms-win-crt-filesystem-l1-1-0.dll .\api-ms-win-crt-filesystem-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
hostpolicy.dll .\hostpolicy.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
coreclr.dll .\coreclr.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
ole32.dll C:\Windows\system32\ole32.dll, version=6.1.7601.24537 (win7sp1_ldr_escrow.191114-1547)
OLEAUT32.dll C:\Windows\system32\OLEAUT32.dll, version=6.1.7601.24537
api-ms-win-crt-utility-l1-1-0.dll .\api-ms-win-crt-utility-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
CRYPTBASE.dll C:\Windows\system32\CRYPTBASE.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707)
System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=6.0.322.12309
MSCOREE.DLL C:\Windows\SYSTEM32\MSCOREE.DLL, version=4.0.40305.0 (Main.040305-0000)
clrjit.dll .\clrjit.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
paintdotnet.dll .\paintdotnet.dll, version=4.310.8103.32785
System.Runtime.dll .\System.Runtime.dll, version=6.0.322.12309
uxtheme.dll C:\Windows\system32\uxtheme.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=4.310.8103.32785
System.Windows.Forms.dll .\System.Windows.Forms.dll, version=6.0.322.12307
System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=6.0.322.12309
TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.20348.0
PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=4.310.8103.32785
System.Runtime.InteropServices.RuntimeInformation.dll .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.322.12309
System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=6.0.322.12309
api-ms-win-core-console-l1-1-0.dll .\api-ms-win-core-console-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-console-l1-2-0.dll .\api-ms-win-core-console-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-datetime-l1-1-0.dll .\api-ms-win-core-datetime-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-debug-l1-1-0.dll .\api-ms-win-core-debug-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-errorhandling-l1-1-0.dll .\api-ms-win-core-errorhandling-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-fibers-l1-1-0.dll .\api-ms-win-core-fibers-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-file-l1-1-0.dll .\api-ms-win-core-file-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-handle-l1-1-0.dll .\api-ms-win-core-handle-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-heap-l1-1-0.dll .\api-ms-win-core-heap-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-interlocked-l1-1-0.dll .\api-ms-win-core-interlocked-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-libraryloader-l1-1-0.dll .\api-ms-win-core-libraryloader-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-memory-l1-1-0.dll .\api-ms-win-core-memory-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-namedpipe-l1-1-0.dll .\api-ms-win-core-namedpipe-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-processenvironment-l1-1-0.dll .\api-ms-win-core-processenvironment-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-processthreads-l1-1-0.dll .\api-ms-win-core-processthreads-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-profile-l1-1-0.dll .\api-ms-win-core-profile-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-rtlsupport-l1-1-0.dll .\api-ms-win-core-rtlsupport-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-string-l1-1-0.dll .\api-ms-win-core-string-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-synch-l1-1-0.dll .\api-ms-win-core-synch-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-sysinfo-l1-1-0.dll .\api-ms-win-core-sysinfo-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-core-util-l1-1-0.dll .\api-ms-win-core-util-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-conio-l1-1-0.dll .\api-ms-win-crt-conio-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-environment-l1-1-0.dll .\api-ms-win-crt-environment-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-multibyte-l1-1-0.dll .\api-ms-win-crt-multibyte-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-private-l1-1-0.dll .\api-ms-win-crt-private-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
api-ms-win-crt-process-l1-1-0.dll .\api-ms-win-crt-process-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800)
vcruntime140.dll .\vcruntime140.dll, version=14.31.31103.0
vcruntime140_1.dll .\vcruntime140_1.dll, version=14.31.31103.0
msvcp140.dll .\msvcp140.dll, version=14.31.31103.0
msvcp140_1.dll .\msvcp140_1.dll, version=14.31.31103.0
msvcp140_2.dll .\msvcp140_2.dll, version=14.31.31103.0
msvcp140_codecvt_ids.dll .\msvcp140_codecvt_ids.dll, version=14.31.31103.0
vcomp140.dll .\vcomp140.dll, version=14.31.31103.0
ijwhost.dll .\ijwhost.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.310.8103.32785
PROPSYS.dll C:\Windows\system32\PROPSYS.dll, version=7.00.7600.16385 (win7_rtm.090713-1255)
gdiplus.dll C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.24542_none_1459e0f08b91b367\gdiplus.dll, version=6.1.7601.24542 (win7sp1_ldr_escrow.191209-2211)
WindowsCodecs.dll C:\Windows\system32\WindowsCodecs.dll, version=6.2.9200.22551 (win8_ldr_escrow.180828-1117)
System.Threading.dll .\System.Threading.dll, version=6.0.322.12309
System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=6.0.322.12309
System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.322.12309
System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=6.0.322.12309
System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=6.0.322.12309
PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=4.310.8103.32785
System.Private.Uri.dll .\System.Private.Uri.dll, version=6.0.322.12309
System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=6.0.322.12309
BCrypt.dll C:\Windows\system32\BCrypt.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707)
bcryptprimitives.dll C:\Windows\system32\bcryptprimitives.dll, version=6.1.7601.23451 (win7sp1_ldr.160511-0600)
System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=6.0.322.12307
System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=6.0.322.12309
WindowsBase.dll .\WindowsBase.dll, version=6.0.322.12402
PresentationFramework.dll .\PresentationFramework.dll, version=6.0.322.12402
System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=6.0.322.12309
System.Xaml.dll .\System.Xaml.dll, version=6.0.322.12402
System.Collections.dll .\System.Collections.dll, version=6.0.322.12309
System.ComponentModel.dll .\System.ComponentModel.dll, version=6.0.322.12309
System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=6.0.322.12309
PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=4.310.8103.32785
System.ObjectModel.dll .\System.ObjectModel.dll, version=6.0.322.12309
System.Threading.Thread.dll .\System.Threading.Thread.dll, version=6.0.322.12309
PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=4.310.8103.32785
Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=6.0.322.12309
System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=6.0.322.12309
Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=6.0.322.12309
System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=6.0.322.12309
System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=6.0.322.12309
System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=6.0.322.12309
System.Private.Xml.dll .\System.Private.Xml.dll, version=6.0.322.12309
PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=6,0,22,10402 @Commit: 962ab77e3d043ec9377feec32e1b26824338e9db
System.Net.WebClient.dll .\System.Net.WebClient.dll, version=6.0.322.12309
System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=6.0.322.12309
PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=4.310.8103.32785
System.Memory.dll .\System.Memory.dll, version=6.0.322.12309
System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=6.0.322.12309
System.Drawing.Common.dll .\System.Drawing.Common.dll, version=6.0.322.12309
CRYPTSP.dll C:\Windows\system32\CRYPTSP.dll, version=6.1.7601.24499 (win7sp1_ldr.190612-0600)
Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=6.0.322.12309
rsaenh.dll C:\Windows\system32\rsaenh.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
RpcRtRemote.dll C:\Windows\system32\RpcRtRemote.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
System.Linq.dll .\System.Linq.dll, version=6.0.322.12309
dwmapi.dll C:\Windows\system32\dwmapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=6.0.322.12309
System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=6.0.322.12309
System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=6.0.322.12309
PresentationCore.dll .\PresentationCore.dll, version=6.0.322.12402
System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=6.0.322.12309
System.Security.Claims.dll .\System.Security.Claims.dll, version=6.0.322.12309
DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=6,0,322,12402 @Commit: 560f243910f407df33fd5cdf06e2a857684f4bc7
dxgi.dll C:\Windows\system32\dxgi.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
VERSION.dll C:\Windows\system32\VERSION.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=6.0.322.12309
dwrite.dll C:\Windows\system32\dwrite.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
d2d1.dll C:\Windows\system32\d2d1.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
WINTRUST.dll C:\Windows\system32\WINTRUST.dll, version=6.1.7601.24542 (win7sp1_ldr_escrow.191209-2211)
CRYPT32.dll C:\Windows\system32\CRYPT32.dll, version=6.1.7601.24542 (win7sp1_ldr_escrow.191209-2211)
MSASN1.dll C:\Windows\system32\MSASN1.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
UIAutomationTypes.dll .\UIAutomationTypes.dll, version=6.0.322.12402
System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=6.0.322.12309
PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=4.310.8103.32785
Accessibility.dll .\Accessibility.dll, version=6.0.322.12307
profapi.dll C:\Windows\system32\profapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
CLBCatQ.DLL C:\Windows\system32\CLBCatQ.DLL, version=2001.12.8530.16385 (win7_rtm.090713-1255)
UIAnimation.dll C:\Windows\System32\UIAnimation.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=6.0.322.12309
comctl32.dll C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24483_none_e372d88f30fbb845\comctl32.dll, version=6.10 (win7_rtm.090713-1255)
System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=6.0.322.12309
System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=6.0.322.12309
DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.11.0
AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.19.0
System.IO.Packaging.dll .\System.IO.Packaging.dll, version=6.0.322.12309
WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.11.0
System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=6.0.322.12309
wtsapi32.dll C:\Windows\system32\wtsapi32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
WINSTA.dll C:\Windows\system32\WINSTA.dll, version=6.1.7601.18540 (win7sp1_gdr.140716-1508)
d3d11.dll C:\Windows\system32\d3d11.dll, version=6.2.9200.16570 (win8_gdr.130327-1526)
D3D10Warp.dll C:\Windows\system32\D3D10Warp.dll, version=6.2.9200.22592 (win8_ldr.181005-0600)
UIAutomationCore.dll C:\Windows\system32\UIAutomationCore.dll, version=7.0.0.0 (win7_rtm.090713-1255)
PSAPI.DLL C:\Windows\system32\PSAPI.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255)
OLEACC.dll C:\Windows\system32\OLEACC.dll, version=7.0.0.0 (win7sp1_gdr.110826-1504)
System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=6.0.322.12309
System.CodeDom.dll .\System.CodeDom.dll, version=6.0.322.12309
mscorlib.dll .\mscorlib.dll, version=6.0.322.12309
System.Console.dll .\System.Console.dll, version=6.0.322.12309
System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=6.0.322.12309
winmm.DLL C:\Windows\system32\winmm.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255)
System.Runtime.CompilerServices.Unsafe.dll .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.322.12309
explorerframe.dll C:\Windows\system32\explorerframe.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
DUser.dll C:\Windows\system32\DUser.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
DUI70.dll C:\Windows\system32\DUI70.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
comdlg32.dll C:\Windows\System32\comdlg32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
SETUPAPI.dll C:\Windows\system32\SETUPAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
CFGMGR32.dll C:\Windows\system32\CFGMGR32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
DEVOBJ.dll C:\Windows\system32\DEVOBJ.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
ntmarta.dll C:\Windows\system32\ntmarta.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
WLDAP32.dll C:\Windows\system32\WLDAP32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
tiptsf.dll C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
apphelp.dll C:\Windows\system32\apphelp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
drivefsext.dll C:\Program Files\Google\Drive File Stream\57.0.5.0\drivefsext.dll, version=57.0.5.0
WININET.dll C:\Windows\system32\WININET.dll, version=11.00.9600.19597 (winblue_ltsb_escrow.191216-1311)
api-ms-win-downlevel-user32-l1-1-0.dll C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
api-ms-win-downlevel-shlwapi-l1-1-0.dll C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
api-ms-win-downlevel-version-l1-1-0.dll C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
api-ms-win-downlevel-normaliz-l1-1-0.dll C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
normaliz.DLL C:\Windows\system32\normaliz.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255)
iertutil.dll C:\Windows\system32\iertutil.dll, version=11.00.9600.19597 (winblue_ltsb_escrow.191216-1311)
api-ms-win-downlevel-advapi32-l1-1-0.dll C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
USERENV.dll C:\Windows\system32\USERENV.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
WS2_32.dll C:\Windows\system32\WS2_32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
NSI.dll C:\Windows\system32\NSI.dll, version=6.1.7601.23889 (win7sp1_ldr.170810-1615)
dbghelp.dll C:\Windows\system32\dbghelp.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
ashShell.dll C:\Program Files\Avast Software\Avast\ashShell.dll, version=22.3.7108.0
POWRPROF.dll C:\Windows\system32\POWRPROF.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
msi.dll C:\Windows\system32\msi.dll, version=5.0.7601.24535
EhStorShell.dll C:\Windows\system32\EhStorShell.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
cscui.dll C:\Windows\System32\cscui.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
CSCDLL.dll C:\Windows\System32\CSCDLL.dll, version=6.1.7601.24197 (win7sp1_ldr.180629-0600)
CSCAPI.dll C:\Windows\system32\CSCAPI.dll, version=6.1.7601.24197 (win7sp1_ldr.180629-0600)
ntshrui.dll C:\Windows\system32\ntshrui.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
srvcli.dll C:\Windows\system32\srvcli.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
slc.dll C:\Windows\system32\slc.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
msls31.dll C:\Windows\system32\msls31.dll, version=3.10.349.0
StructuredQuery.dll C:\Windows\System32\StructuredQuery.dll, version=7.00.7601.24542 (win7sp1_ldr_escrow.191209-2211)
Secur32.dll C:\Windows\System32\Secur32.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707)
SSPICLI.DLL C:\Windows\system32\SSPICLI.DLL, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707)
actxprxy.dll C:\Windows\system32\actxprxy.dll, version=6.1.7601.24000 (win7sp1_ldr.171231-1547)
ieproxy.dll C:\Program Files\Internet Explorer\ieproxy.dll, version=11.00.9600.19597 (winblue_ltsb_escrow.191216-1311)
api-ms-win-downlevel-shlwapi-l2-1-0.dll C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
thumbcache.dll C:\Windows\system32\thumbcache.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
SHDOCVW.dll C:\Windows\system32\SHDOCVW.dll, version=6.1.7601.23896 (win7sp1_ldr.170819-0600)
ieframe.DLL C:\Windows\system32\ieframe.DLL, version=11.00.9600.19597 (winblue_ltsb_escrow.191216-1311)
api-ms-win-downlevel-shell32-l1-1-0.dll C:\Windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
WINHTTP.dll C:\Windows\system32\WINHTTP.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
webio.dll C:\Windows\system32\webio.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
IconCodecService.dll C:\Windows\system32\IconCodecService.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
SearchFolder.dll C:\Windows\system32\SearchFolder.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
MPR.dll C:\Windows\system32\MPR.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
drprov.dll C:\Windows\System32\drprov.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
ntlanman.dll C:\Windows\System32\ntlanman.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
davclnt.dll C:\Windows\System32\davclnt.dll, version=6.1.7601.23542 (win7sp1_ldr.160908-0600)
DAVHLPR.dll C:\Windows\System32\DAVHLPR.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
wkscli.dll C:\Windows\system32\wkscli.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
netutils.dll C:\Windows\system32\netutils.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850)
wpdshext.dll C:\Windows\system32\wpdshext.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
PortableDeviceApi.dll C:\Windows\system32\PortableDeviceApi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
PortableDeviceTypes.dll C:\Windows\system32\PortableDeviceTypes.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
NetworkExplorer.dll C:\Windows\system32\NetworkExplorer.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
EhStorAPI.dll C:\Windows\system32\EhStorAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
zipfldr.dll C:\Windows\system32\zipfldr.dll, version=6.1.7600.16385 (win7_rtm.090713-1255)
MsftEdit.DLL C:\Windows\system32\MsftEdit.DLL, version=5.41.21.2510
Microsoft.DiaSymReader.Native.amd64.dll .\Microsoft.DiaSymReader.Native.amd64.dll, version=14.28.29715.1 built by: vcwrkspc
System.Diagnostics.StackTrace.dll .\System.Diagnostics.StackTrace.dll, version=6.0.322.12309
System.Reflection.Metadata.dll .\System.Reflection.Metadata.dll, version=6.0.322.12309
XnView doesn''t show thumbnails in windows explorerjazei wrote: Wed May 04, 2022 5:25 pm I downloaded and installed of course it and the same for the patch before, but XnView does not show avif files in the interfase of Xnview exporer of a folder that contains a mix of .jpg .webp and .avif (avif made by another program "paint.net") files of my PC, even the data of the avif file created by XnView shows size: 0 bites!!!!! see screenshot using windows explorer: below say = 0 bites
jazei
you read wrong... I write that XnView does not show avif files in the interfase of Xnview explorer.xnview wrote: Thu May 05, 2022 2:00 pmXnView doesn''t show thumbnails in windows explorerjazei wrote: Wed May 04, 2022 5:25 pm I downloaded and installed of course it and the same for the patch before, but XnView does not show avif files in the interfase of Xnview explorer of a folder that contains a mix of .jpg .webp and .avif (avif made by another program "paint.net") files of my PC, even the data of the avif file created by XnView shows size: 0 bites!!!!! see screenshot using windows explorer: below say = 0 bites
I do not speaking about windows explorer...I'm speaking about XnV explorer
no problem here on Win 7 x64 to load AVIF file (or to convert to). Please send me a an avif file test
