Manjaro KDE: Crashes with Zoom-In
kishinnokamen
Post by kishinnokamen »
Whenever images require zoom-in, they crash. This happens with any filter above bilinear. I am using Manjaro KDE, and I have updated XnView. I am also using the libs version.
/opt/xnviewmp/XnView: symbol lookup error: /opt/xnviewmp/XnView: undefined symbol: _ZdlPvm, version Qt_5
Re: Manjaro KDE: Crashes with Zoom-In
sorry but i can't reproduce, are you sur that you are using libs from package? which settings>View do you have?
kishinnokamen
I am positive that I am using the libs version.
and if you use bilinear?
kishinnokamen
No crashes on bilinear. It's just whenever I go above that filter that it crashes, and only if the viewer has to zoom in.
kishinnokamen wrote: Fri May 13, 2022 1:46 am No crashes on bilinear. It's just whenever I go above that filter that it crashes, and only if the viewer has to zoom in.
Strange, i can't reproduce on ubuntu, no crash with previous version?
kishinnokamen
The crash was always there. I just thought it was worth noting that I actually did update. Here's the inxi, in case that makes a difference.
CPU: 8-core AMD Ryzen 7 5800X (-MT MCP-) speed/min/max: 3576/2200/4850 MHz
Kernel: 5.15.28-1-MANJARO x86_64 Up: 6d 19h 45m
Mem: 27201.8/64312.3 MiB (42.3%) Storage: 20.01 TiB (39.7% used) Procs: 526
Shell: Zsh inxi: 3.3.14
i've installed the latest version of Manjaro KDE, and no problem :(
kishinnokamen
That is really strange. I wonder if I'm missing some kind of dependency?
kasiuskaktus
Post by kasiuskaktus »
Hi. I'm facing the same issue. However, I'm on Arch. I use the version xnviewmp-system-libs from the AUR. Obviously, this version is not using the included libs. I was able to "fix" this issue by appending the following line to file qt5_std_fun_forwarder.S before building the package.
DEFINE_QT5_FORWARDER(_ZdlPvm)
I think it's a symbol mismatch. Xnview is linked against it's own library libQt5Core.so.5.15.6 and expects _ZdlPvm@@Qt_5. Arch is using libQt5Core.so.5.15.5 which has _ZdlPvm@CXXABI_1.3.9. I know, it's just another hack. But it works for v1.00. Haven't tried it with 1.02 though.
