1.0 Hidden files broken [directory tree]
MARK2580
Post by MARK2580 »
Some time ago I requested to add a "hide/show hidden files" button. I waited for it in version 1.0. But I noticed a rather unpleasant bug. :bugconfirmed:
viewtopic.php?f=104&t=40848
For example, if the program was launched with the display of hidden files turned off, then when the button is pressed, hidden files are displayed only in Explorer itself, but nothing happens in the directory tree, hidden folders continue not to be displayed there.
If you restart the program with the button pressed, then some folders start to appear in the directory tree, but still, for some reason, not all of them.
Re: 1.0 Hidden files broken [directory tree]
so the problem is only with folder tree view, right?
MARK2580
Post by MARK2580 »
xnview wrote: Mon May 09, 2022 7:23 am so the problem is only with folder tree view, right?
Yes, that's right. For some reason, the directory tree does not respond to switching the display mode of hidden files.
zarlan
Banned
Post by zarlan »
Some of that, sounds similar to what I describe in viewtopic.php?f=62&t=43276
do you have always this problem with 1.4.2? I have 'Recovery' or 'Program Data'
