1.00: Show Companion File Toggle Not Functional
mrbutton
Post by mrbutton »
XnView: MP 1.00 64-bit
OS: Windows 11
I frequently use the "Show Companion Files" toggle to show/hide Fujifilm raw files (.RAF extension). After installing 1.00, I found that toggling this on/off does nothing, and all RAF files show regardless of setting. I am unsure if this applies to other types of files at the moment.
Effect: Files are not hidden from file list as expected or observed on previous versions.
Unclear. In this case toggle the option and see if it works. I have uninstalled/reinstalled the program, and removed and re-added "RAF" to the companion definitions list. Neither attempt corrected the issue.
mrbutton
Re: 1.00: Show Companion File Toggle Not Functional
Post by mrbutton »
Reverting back to 0.99.7 immediately corrected the issue.
This problem is supposed to be fixed in XnView MP 1.01. Please check and confirm the bug fix here.
efito
Post by efito »
Thank´s a lot Pierre!
The file toggle is functional again!
Just have to show the sign Information: "Please restart XnView" (It´s a must to do this...)
I hope my english pueda entenderse, It´s not my mother language...
efito
"...de modo que lo que se ve fue hecho de lo que no se veía." :idea:
