b2: *.PPS doesn't work in ß2
:) Hello !
- The PPS file type is not recognized in the 1.84 ß-2. I get the ususal hellish message.
- I added PPS in the "Custom" field of "Files displayed", same.
- As thumb-nail, I get only the icon of the type, and no display in any mode, still the message :(
- Indeed, it works in 1.80.3
:mrgreen: KR
Aokromes
Post by Aokromes »
It's quite strange, for me it works fine, i have tryed with: http://www.powerpoints.org/pop.php?pps=humor307 and others without trouble.
Re: b2: *.PPS doesn't work in ß2
Clo wrote::) Hello !
not recognized means not shown in thumbnail view??
Doesn't work at all
:) Hello !
- I mean : it is not displayed in view, and I have the file-type icon in the board of thumb-nails.
- It doesn't work at all, I have the message " The file xyz.pps has a format which can be defined" or so.
- Same trying to open from any way:
¤ click on the thumb-nail —> Message
¤ open from the tool-bar —> Message
¤ open from the menu —> Message
¤ Drag & Drop in Total Commander on the icon —> Message
:mrgreen: KR
Re: Doesn't work at all
Do you have options/Startup/Use all formats?
Why 2 conflictual ways ?
:) Hello !
- It's the point ! It works if I tick that box, but there is an inconsistency there :
- If you state such a format in "Displayed files", it might be displayed anyway in all modes.
- Features and options applied differently to various display modes are confusing.
:mrgreen: K R
Re: Why 2 conflictual ways ?
No this option initialize my base library with all formats available or not
Fire it !
:) Hello Pierre !
- Hence, it might be enabled by default… and even be removed as an option (set enabled in the code), only usable as an extra-INI entry to disable it in some special cases, I guess…
:mrgreen: KR
Re: Fire it !
Clo wrote::) Hello Pierre !
No, not enabled by default, because many users don't want to use all formats.
Î Back above !
:) Hi again!
- So, back to above !!! If one doesn't want all formats, the ones stated -like I did- MUST work, and they don't !
:mrgreen: KR
marsh
Post by marsh »
What about 'Include box' for file types and 'Exclude box' for files displayed?
Cheers,
Bruce
Post by Guest »
b2, deleted ini.
PPS files are displayed as icons (OK), double click displays file in PowerPoint (OK), so no confirmation here.
Clo, if you still think there is problem, make a diff of ini files- clean and the one with which there is problem?
X.
Or like…
:arrow: marsh
:) Hello B. !
- First, I wish you a Merry X-Mas !
¤ This could be treated as well like in the last § of that thread :wink:
¤ Use all formats disabled by default sounds illogical for me, and I'm pretty sure that many users will fall in the trap !
:mrgreen: Kind regards,
Xyzzy
Post by Xyzzy »
Seems no real problem to fix here. Move to Closed.
X.
Dreamer
Post by Dreamer »
Xyzzy wrote:Seems no real problem to fix here. Move to Closed.
X.
Clo, agree?
Locked
