Ich hätte da einen Vorschlag bzw. Wunsch umgesetzt.
Wenn bei der Diashow der Dateiname ohne Erweiterung eingesetzt wird, ist es möglich bestimmte Zeichen auszublenden ?
Wenn ich folgende Dateinamen habe:
01 Beschriftung 2022 xxx
02 Beschriftung 2022 xxx
03 Beschriftung 2022 xxx
so sollte die Beschriftung so aussehen:
Viele Grüße
Manfred
I would have implemented a suggestion or wish.
If the file name is used without an extension in the slide show, is it possible to hide certain characters?
If I have the following filenames:
so the caption should look like this:
Many greetings
Manfred
Slide show: Display filename without specific chars
ML_1
Re: Slide show: Display filename without specific chars
Thank you for your problem report in English and German, Manfred. Currently, filename in info is identical to the actual filename. And I much doubt that there are plans to change this. What you might do is renaming your files and remove the number prefix 01, 02, .... For renaming you can use "{Filename}" as name template and in section replace you enter "^[0-9]* " (without double quotes, please note the space char at the end) and check "regular expression". Field "With" remains empty.
Sure enough this is a workaround and I'm not sure whether renaming your files for viewing in a slide show is practical at all.
do you have tried place holder part like
<Filename [3-]>-
Wow, I expected these placeholder parts to work in batch rename, only. But in fact these placeholders parts also work when using these in Tools > Settings | View | Info, textbox "Information displayed".xnview wrote: Mon May 23, 2022 12:20 pm do you have tried place holder part likeCode: Select all
<Filename [3-]>
- Forum Librarian
Added to XnView MP - User Guidexnview wrote: Mon May 23, 2022 12:20 pm do you have tried place holder part likeCode: Select all
<Filename [3-]>
ML_1
that works great, thanks!
regards
Manfred
regards
Manfred
