Right now, no shortcuts are supported in compare window. I see two possibilities:
a) change context menu -> no shortcuts
b) implement shortcuts (at least for pan and zoom)
Yes i must fix that, i use the same context menu than view modeFlorianH wrote:The context menu of the compare window lists the shortcut '/' to fit image to window for all images (images larger and smaller than window). But it doesn't work.
a) change context menu -> no shortcuts![]()
