Version 1.0 - Bulk Convert -> Delete Original leaves "ghost" file
Bob_in_MA
Post by Bob_in_MA »
1. While in browser viewing images...
2. I assign categories and/or ratings
3. I then do a bulk convert,
a) configuring a new file name
b) checking "Delete original"
(Conversion works fine and the contents of the directory appears normal.)
4. I go to the categories filter and select a category used by one of the converted files.
5. The converted file shows up, but so does a "ghost" with the original file name, but lacking a thumbnail. This ghost has the categories and ratings, but not the bulk of the metadata. It can't be deleted, unless I delete the entire directory.
Thanks!
Re: Version 1.0 - Bulk Convert -> Delete Original leaves "ghost" file
do you write categories in XMP metadata?
