Playing WMV files in Xnview 1.80.03
brizboy
Post by brizboy »
I have recently reinstalled Windows XP and the above version of XnView. Now when I play WMV files using Xn the progress bar (with volume and stop start pause butttons) appear and the progress bar moves but no video is rendered only sound. I have installed Plugin Zip Files but this has not fixed the problem.
I did not have this problem with Ver 1.74.
Possibly someone can suggest a download or reg fix that will repair it
Thanks in advance
Brizboy
Re: Playing WMV files in Xnview 1.80.03
brizboy wrote:I have recently reinstalled Windows XP and the above version of XnView. Now when I play WMV files using Xn the progress bar (with volume and stop start pause butttons) appear and the progress bar moves but no video is rendered only sound. I have installed Plugin Zip Files but this has not fixed the problem.
Do you have Xp Home or Pro?
brizboy
Post by brizboy »
Sorry for not giving full info. I have Windows Xp Professional
Tks
brizboy
brizboy wrote:Sorry for not giving full info. I have Windows Xp Professional
Is it possible to have a sample?
