1.0: Browser bugs: Tooltips, Details view
ilcane87
Post by ilcane87 »
Hello, first of all I'm running XnView MP Windows Version 1.0 64bits (Apr 28 2022), Libformat version 7.110, on Windows 10 Pro x64.
  • Tooltips problem
    I set up custom browser tooltips like this:
    <b>{Filename With Ext}</b><br>{Categories}<br>{Directory}<br>Creation date: {Creation Date}<br>Modified date: {Modified Date}<br>{Size KB} Kib
    The custom fields show correctly for a minority of files:
    But most files display some kind of default tooltip instead:
    I've only tested this on mp3 files so far.
  • Details view problem
    The 'Categories' field is not populated with any of the assigned Categories:
    This as well I've only tested on mp3 files so far.
This is my first post here so I'll take the opportunity to thank everyone involved for this awesome piece of software. :wink:
Re: 1.0: Two Browser bugs (Tooltips, Details view)
ilcane87 wrote: Fri Jun 10, 2022 12:10 pm
  • Tooltips problem
Could you send me one sample file for each?
This 'Category' field is taken from IPTC
ilcane87
Post by ilcane87 »
xnview wrote: Mon Jun 13, 2022 1:23 pm Could you send me one sample file for each?
While looking for files to send you, I realized something: only the files downloaded from a certain user seem to have a working tooltip for some reason.
So I made a copy of a working file and checked the media details:
Then I altered a single field (added a character to the title), and applied the changes. After checking again, the media details were entirely gone, and the tooltips don't work anymore:
The details being gone is probably unrelated to XNView, it happens even when working from windows explorer with the program closed, although I noticed that sometimes I'm unable to edit the details when XNView is opened.
Don't know why it's affecting tooltips though, there are other mp3 files with populated details that still show the wrong tooltips, but those can be edited without them all disappearing later.
Here's two samples, the original file that gets correct tooltips, and the copy without media details that gets the wrong tooltips:
https://www.mediafire.com/file/woy6btvj ... c.zip/file
The song is freely distributed under the CC-BY 3.0 license btw.
xnview wrote: Mon Jun 13, 2022 1:23 pm This 'Category' field is taken from IPTC
Oh, then I guess I'll post a suggestion to add the actual categories to the details view, that would come in handy when you don't need to use the Thumbnails view, such as with music files.
Post by michel038 »
A suggestion already exists :
viewtopic.php?f=60&t=43439
