Subject: 1.0: Checking or unchecking (Menu: View->Use alpha channel), (Menu: View->Show alpha) has no effect when using "High zoom quality".
XnView: MP 1.0 64 bit
OS: Windows 10 21H2 64bit
When viewing a png with transparency and using "High zoom quality", checking or unchecking (Menu: View->Use alpha channel), (Menu: View->Show alpha) has no effect. (This happens sometimes, not on every image. I will upload a sample image)
Effect: When using "High zoom quality", checking or unchecking (Menu: View->Use alpha channel), (Menu: View->Show alpha) has no effect. Please see the attached image.
1. open a png image with transparency
2. Turn on "High zoom quality", check or uncheck (Menu: View->Use alpha channel), (Menu: View->Show alpha)
3. Problem may occur: The display may change.
Actual behaviour (bug): When using "High zoom quality", checking or unchecking (Menu: View->Use alpha channel), (Menu: View->Show alpha) has no effect.
Expected behaviour: When using "High zoom quality", (Menu: View->Use alpha channel), (Menu: View->Show alpha) options work fine.
Screenshot 1: High zoom quality (ON), Show alpha (ON)
Screenshot 2: High zoom quality (OFF), Show alpha (ON)
Sample images:
1.0: Checking or unchecking "Use alpha channel" "Show alpha" has no effect when using "High zoom quality"
lffs
- Forum Librarian
Re: 1.0: Checking or unchecking "Use alpha channel" "Show alpha" has no effect when using "High zoom quality"
Confirmed
Only if Bilinear is chosen as the algorithm for High zoom quality in Tools → Settings… → View → View, everything works as expected.
do you have always the problem in 1.4.2?
- Forum Librarian
- Forum Librarian
There's a new problem in v1.4.2 if High zoom quality in Tools → Settings… → View → View is set to Zoom-out & Zoom-in and Bicubic:
I can't reproduce, could you send me the image used?XnTriq wrote: Tue Feb 14, 2023 4:30 am There's a new problem in v1.4.2 if High zoom quality in Tools → Settings… → View → View is set to Zoom-out & Zoom-in and Bicubic:
- Forum Librarian
It's the file posted by the thread starter (lffs): sample1.png
i can't reproduce, do you use windows font scaling?XnTriq wrote: Mon Feb 27, 2023 4:00 amIt's the file posted by the thread starter (lffs): sample1.png
- Forum Librarian
Yes (125%). When I turn it off (100%), the problem does not occur.
FYI: Zoom on HiDPI screen: 1 image pixel equals 1 screen pixel in Tools → Settings… → View → View is activated.
